Results 1 to 7 of 7
Thread: Nikasil plating?
  1. #1
    Rider
    Join Date
    Nov 2014
    Location
    nc
    Posts
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    Nikasil plating?
    I have the opportunity to pick up an older 310 cylinder. I've been told it's at 73.5mm now and most likely will need to be bored. I was wondering if going 74mm and having it nikasil plated would be an option I think this cylinder is an older sparks ported cylinder. Is it possible to run 74mm on unbored cases and a stock transmission?
    Sent from my Z981 using Tapatalk
  2. #2
    Pro-X
    Join Date
    Oct 2013
    Location
    Phoenix Arizona
    Posts
    636
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Feedback Score
    0
    If the cylinder is currently 73.5mm, needing bored but would clean up by removing .25mm to .30mm it can be plated back to 73.5mm. The plating is typically .10mm to .15mm thick on each wall.
  3. #3
    Rider
    Join Date
    Nov 2014
    Location
    nc
    Posts
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    How much is it typically to plate a cylinder vs a new sleeve
  4. #4
    Pro-X Rupp250's Avatar
    Join Date
    Jul 2013
    Location
    Bay Area
    Posts
    827
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Feedback Score
    1 (100%)
    Contact Millennium. On phone right now other wise I would put the link up
    DUNER -86 250R Flinstone
  5. #5
    Super Moderator Tbone07's Avatar
    Join Date
    Oct 2013
    Posts
    1,186
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Feedback Score
    1 (100%)
    Around $225 for plating. If it truly is a Sparks cylinder I would definitely get the plating done and preserve that bad boy. Shouldn't need to bore the cases for a 310
    RIP Lazarus Sommers
  6. #6
    Rider
    Join Date
    Nov 2014
    Location
    nc
    Posts
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    How can you tell if it's a sparks?
  7. #7
    Join Date
    Oct 2013
    Posts
    1,186
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Feedback Score
    1 (100%)
    Quote Originally Posted by seth View Post
    Engraving/markings on the cylinder. Post up some pics
    RIP Lazarus Sommers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
