Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 41
Thread: Something Im working on.
  1. #21
    Racer mrtwidster1's Avatar
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Thanks! Yes I have access to a lathe. That is how i modified the pulley on the axle nut.
  2. #22
    Pro-X Rupp250's Avatar
    Join Date
    Jul 2013
    Location
    Bay Area
    Posts
    827
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Feedback Score
    1 (100%)
    Here are some pics for reference. The fence is probably 500ft away. The one is with the brights on and the other is with the LEDs.
    Attached Images Attached Images
    DUNER -86 250R Flinstone
  3. #23
    Join Date
    Jul 2013
    Location
    Bay Area
    Posts
    827
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Feedback Score
    1 (100%)
    Leds
  4. #24
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    I researched many lights. Led has come a long way no doubt. Thanks for the Pics as well as the input. It is appreciated.
  5. #25
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    One note here also. If I could have found a comparable alternator that had smaller dimensions. I would have used it. Of course the the ac voltage will be run through a regulator rectifier and converted to dc.
    Also, no more than I will be using the lights I could have used just a battery but I just wanted to try something different.
  6. #26
    Rider
    Join Date
    Jul 2013
    Location
    Squaw Valley, CA
    Posts
    64
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    I like your design. Another thought that I had but haven't tinkered enough yet to get around to it was to mount the alternator to the swing arm but in line with the chain. I was thinking of using a toothed sprocket for the alternator pulley and a spring to apply tension. Basically using the chain as the belt.
    I have a friend with a crf 450 hybrid. He had the stator re-wrapped and it can now support 250 watt's. I think he used Ricky Stator.
    On my R I run a Ricky Stator high output and I prefer it over the CR ignition. (Mainly because I ride a lot at night.) The performance gain just wasn't a fair trade-off.
  7. #27
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Originally I was going to run it off of the chain. Once I started studying out the mechanics and seeing that i would have to apply tension to allow for the pivot arch of the swing arm, I decided to go this route because I was concerned that the chain method would be high maintenance. At my age, I don't need anything "HIGH MAINTENANCE".
  8. #28
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Guard
  9. #29
    Racer ytman's Avatar
    Join Date
    Jul 2013
    Location
    Palmdale,Ca
    Posts
    278
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Feedback Score
    0
    This is cool. Are you worried about the tension from the belt "adjusting" the axle nut while it's turning?
  10. #30
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    The OEM lock nut is locked against the pulley and the pulley is recessed over the primary nut housing. The pulley acts as a spacer so there is no loss of locking force of to the lock nut. I do have a concern about the pulley being aluminium but it is aircraft grade. If i need to I will make the primary nut a squeeze type lock. Just experimenting now. Being left hand threaded may help keep it tight.
    I appreciate your input.
  11. #31
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Little update here on this project.
    Since i now have the bike up and running that this is on, I tried it out. It will work and indeed put out the voltage i need (13V). Yea!!! but... I have to hit 76 miles per hr before the flux capacitor will kick in. HAHAHA (Just a joke there). in reality about 40 mph.
    I need to make a bigger pulley for the drive side about 8 inches. I have sourced the billet aluminum I need and my machinist will put it on the "lathe a runi " and fix me up. Hopefully i will have it completed by the OCT ride at ST JOE.
    I will update when I make more progress or if i get a letter saying I am being sued by DeLorean or DOC Brown.
  12. #32
    Pro-X Hawaiiysr's Avatar
    Join Date
    Jul 2013
    Location
    808 sTaTe HAWAII!!!
    Posts
    872
    Post Thanks / Like
    Mentioned
    14 Post(s)
    Feedback Score
    1 (100%)
    Interesting. Thinking outside the box. I like
  13. #33
    Racer
    Join Date
    Mar 2014
    Location
    Austin TX
    Posts
    339
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Feedback Score
    0
    I wouldn't worry about it, Doc is a good guy. What is St Joe?
  14. #34
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    ST Joe Park in MO. Ride planned there on the 8-10 next month
  15. #35
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Little update. Made a larger Dia pulley and installed the matching Kubota regulator/rectifier and I get 13.5 volts at about 25 mph. I will put a sealed battery and make a wiring harness and I should be good to go. Just trying to do something unusual. Like was suggested, I may give the LED a try. I can buy H4 socket Led bulbs to put in my existing light choice.
    The light bar came with an old set of Dick Cepeck lights. I may powder coat the cans and use them. They also take the H4.
    I made the light bar so it could be installed/removed in a few min. I will be able to put the white Maire head light on easy.
  16. #36
    Administrator havinnoj's Avatar
    Join Date
    Jul 2013
    Location
    Portland, OR / West Palm Beach, FL
    Posts
    1,428
    Post Thanks / Like
    Mentioned
    20 Post(s)
    Feedback Score
    2 (100%)
    My hats off to you @mrtwidster1 - this is slick!
  17. #37
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    ^^^^^ Thanks
  18. #38
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    Battery and voltage reg operational. Lights work. Maintains 12.5 volt charge to battery. I will put the electrical through some testing this spring. Once it is proven dependable I will make a proper wiring harness.
  19. #39
    Racer Robsessed86's Avatar
    Join Date
    Oct 2015
    Location
    Maryland
    Posts
    195
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    1 (100%)
    You have created something very impressive mrtwidster1. You have a creative mind. I'm looking forward to a tried and tested review B/c I may have interest in being a customer if you decide to sell a package to make this work.
  20. #40
    Join Date
    Jul 2013
    Posts
    234
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Feedback Score
    0
    I will update after i have used it awhile. If it proves dependable then I will do a full spec write up. Thanks for the interest.
    One spot one flood. I will put h4 led bulbs in eventually and try them.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
