Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 85
Thread: Mini-tooth
  1. #41
    Supporting Member Pumashine's Avatar
    Join Date
    Jul 2013
    Location
    97405 zip 90 minutes to Winchester Bay
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    Quote Originally Posted by sameltoe View Post
    But we've all been told a pv is useless above 330
    The guy was a freakin genius. I am thinking there is a reason he spent alot of time outfitting these 1200cc motors with power valves. Don't ya think?
    Puma 408, Puma 431, Pilot 412, Puma 431, Mini-tooth 486 Trx450r
    89mm Mini tooth Shearer in frame pipe chromed! Mounted with Cascade QUIET Silencer
    All motors built by Pete at hybrid 360-281-2274 SIMPLY THE BEST PORT TIMINGS AVAILABLE
    Looking for Bling? http://www.tlr-online.com/trx250r/dress_up
  2. #42
    Pro-X
    Join Date
    Jul 2013
    Posts
    842
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Feedback Score
    0
    when you live in a fairly tale world you can pretend to be anything you want !!
    which reminds me. every sentance he posts has a "IMO" at the end of it. probly because hes never tested anything himself so he cant answer any question with a factual answer. "IMO" leaves him an escape route out the back door when someone proves him wrong
  3. #43
    Pro-X sameltoe's Avatar
    Join Date
    Jul 2013
    Location
    Iowa
    Posts
    779
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Feedback Score
    0
    Quote Originally Posted by Pumashine View Post
    I would think so!
    I like the pv personally... makes her smooth to ride...
    Arens, Houser, Axis, BHP 363
  4. #44
    Sphynx rsss396's Avatar
    Join Date
    Jul 2013
    Location
    crown point IN
    Posts
    1,402
    Post Thanks / Like
    Mentioned
    14 Post(s)
    Feedback Score
    0
    I hunted down a used power valve for a saber in Canada, not sure how it ever worked out for him.
    i know CP is not going to offer a power valve on the sphynx anymore because of issues of not getting good performance with them. If you could operate it with a electric servo motor and custom cdi to operate it (Ignitech does this) then I think you could make a great running power valve motor the pressure operated ones work ok with snowmobiles because they never use the over rev part of the power band. In over rev the pressure drops in the pipe and the power valve starts to close killing the over rev.
    keeping the exhaust port port timing low will build you allot of low end power and is much simpler and reliable
  5. #45
    Pro-X
    Join Date
    Oct 2013
    Location
    Phoenix Arizona
    Posts
    649
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Feedback Score
    0
    Quote Originally Posted by rsss396 View Post
    ................ then I think you could make a great running power valve motor the pressure operated ones work ok with snowmobiles because they never use the over rev part of the power band. In over rev the pressure drops in the pipe and the power valve starts to close killing the over rev..................
    YES.....YES.........YES........
    It is very refreshing to see others are beginning to see some of the shortcomings of the pressure operated power valves. I started trying to improve on the pressure operated valves on the Rotax road racing engines in the mid 1980s. I gave up after a few years of beating my head against the wall on this primitive method of operating and controlling a two stroke exhaust valve.
  6. #46
    Administrator havinnoj's Avatar
    Join Date
    Jul 2013
    Location
    Portland, OR / West Palm Beach, FL
    Posts
    1,431
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Feedback Score
    2 (100%)
    Video of @traxman's second ever pass on the MiniTooth. Dogged off the line in this one but cleans out nicely. Should be a nice runner when it's tuned.
  7. #47
    Join Date
    Jul 2013
    Location
    crown point IN
    Posts
    1,402
    Post Thanks / Like
    Mentioned
    14 Post(s)
    Feedback Score
    0
    Bike looks strong for its first few passes!
  8. #48
    Rider
    Join Date
    Jul 2013
    Posts
    97
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Feedback Score
    0
    lol Look at the smoke trail it leaves!! It was pig rich, but I was too afraid to look back and see.. lol It was the first time on it since last dunefest for one pass besides the couple test hits that resulted in a broken frame. I was a little nervous being @ the line wondering how my repairs where going to hold up. That run was my first pass, the second pass really bogged and my third pass it did really well and carried the front to the 280' area..
  9. #49
    Join Date
    Jul 2013
    Location
    crown point IN
    Posts
    1,402
    Post Thanks / Like
    Mentioned
    14 Post(s)
    Feedback Score
    0
    Yes lots of smoke haha! its tough to run them at the track for the first time, not like racing in the dunes where you just hotlap and make another run if it wasnt good. IMO tuning for the track is differant than the dunes because you need to be on the leaner side so the bike is not loaded up. But in the dunes we like them richer because if racing gets good you just keep hot lapping them.
  10. #50
    Rider
    Join Date
    Jul 2013
    Posts
    97
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Feedback Score
    0
    Not me!! I lean it up at the dunes so I have a reason to stop loosing after three races against banshees double my displacement!! Lmao!
  11. #51
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    A thanks to Damon AKA Traxman for giving us a little taste of the power of the mini tooth. He is running an out of frame drag pipe so the angle of the pipe can be adapted easier for the Caracal cylinder. This cylinder was not made for a Honda trx250r. It was intended as a twin or triple on a Banshee. The angle of the exhaust is at least 6 degrees different than a Honda. So heres how a Puma in-frame pipe fits the Caracal.
    Will have to cut a pie shape the same as the wedge space created in the pic. It will just be the opposite (180 degrees) taken off the pipe
    The good thing is that this gives me a little room to play with moving the pipe to where it fits the best. Looks like real good kicker clearance.
    Also got just enough room for the coolant line from the back of the cylinder to the clutch cover
  12. #52
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    I cut a piece of metal the same width as the pipe flange so it will clamp in the band-saw. I am going to cut right along a weld. Marked center with a scribe line and some more marks for reference. Set pipe close to perpendicular with the blade and cut.
    Hold the pipe like its going to mount
    Them make a mark where the pipe overlaps to get it close to where you want to cut.
    Using the marks as a guide to sand off the pie shape to get the pipe to fit correctly before tack weld in place.
  13. #53
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    Quote Originally Posted by spiritaces View Post
    Man you got it. I'd be scared to start fabbing and hacking lol
    Hacking? Thats not what we call it. But OK sure. Took about 3 minutes to sand the header piece.
    Looking from the top, much better than before. Pipe is centered and clears everything.
    Now its time to put clearance spacers anywhere the pipe may touch the frame. I like to use 1/8" rubber to flex where it needs to go. Get it where you want it and mark the mating pieces in a few places. Marker tends to rub off. Scribe lines tend to move the pipe around. Then you can take it to the welder and have him tack it in 3 places. Go back and check the fit before welding all the way around.
  14. #54
    Join Date
    Jul 2013
    Location
    crown point IN
    Posts
    1,402
    Post Thanks / Like
    Mentioned
    14 Post(s)
    Feedback Score
    0
    The better way to have done that would have been to use a protractor and measure the angle needed to fix the alignment and then cut the pipe at half that angle. Then turn the pipe flange 180 from where it was, only bad thing is the spring mounts would have to moved also.
    The reason it's better to do it this way you only loose the length of the blade width, but it did not look like you removed allot to do your mod so it probably did not hurt anything
  15. #55
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    Thanks for the advice Dave. I did take all that into consideration. I needed to take off 3/16"-1/4" on the high side of the pie. I thought about taking 1/2 off both sections. So about 1/8" to nothing on each. What I did not show was the pipe was actually to long to fit into the frame. It was hitting the a-arm mounts that I cut away about 1/4". I lost about 1/8" from front to back as the pipe spring mounts are about centered. The band-saw is .030" thick. Worked out about perfect just doing the pie off the flange (even had clearance on the water hose which has never happened before). After I get the pipe centered with clearance everywhere I can sand the flange a little to make a perfect fit for weld.
    What I am saying is since this is not a 250r cylinder it actually worked to my advantage where the exhaust flange ended up. That and Matt's pipes are all a little different. I compared this one to another one I acquired recently. The pipe spring mounts were 1/4"-3/8" further away from the cylinder on this one. So now its perfect as far as I can tell. Just got lucky today.
  16. #56
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    So I got the pipe welded up.
    Clears the brake mount
    Clears the a-arm
    In the Smart carb thread Dave suggested mounting the Smart carb to the CR500 intake with an adapter plater I made him. Looks like this.
    So I did the same and got this set up!
    So I ready to mount the carb after polishing the adapter plate
  17. #57
    Racer Morse250r's Avatar
    Join Date
    Jul 2013
    Location
    St Clair mi and silver lake mi
    Posts
    268
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Feedback Score
    0
    Nice work. !
    88 rb racing duner
    Trx 70's
    Atc 125
  18. #58
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    Time to get this monster back on track. Building a stinger to get from Shearer inframe pipe to Cascade silencer. The polished one on top was a fixxed stinger off the ESR 5 big bore pipe. Using a large radius on the new stinger for better air flow.
  19. #59
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    Exhaust in place
    Smart carb had to be reworked as the OEM cr500 intake boot I purchsed new is a lil too long. Fixed the issue by taking the one off my sons CR500 and fitting it on being careful to drill mounting holes a lil higher to lower the whole carb as much as possible. It now clears the frame with lt500 intake boot installed. Thanks to Jared AKA Skeans1 for this idea.
    Time to dissemble mock up and paint the frame.
  20. #60
    Join Date
    Jul 2013
    Location
    Posts
    2,400
    Post Thanks / Like
    Mentioned
    36 Post(s)
    Feedback Score
    5 (100%)
    I don't have much experience shooting metal flake
    Suns too bright to see the flakes but you can see them in the shaded part towards to back in this pic
    In the sunlight the red is close to Honda red but it is much darker in the shade. This is the color I was aiming for.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
