Results 1 to 6 of 6
Thread: jetting?
  1. #1
    Rider
    Join Date
    Jul 2013
    Location
    indianapolis
    Posts
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    jetting?
    88 motor stock stroke stock port 67.20 bore, cr ignition,v force3 reed cage,38as carb, trx5 pipe cool head with 18cc dome vp110 gas live in indiana. What jetting do you think I need? Thanks
  2. #2
    Racer PORTED R's Avatar
    Join Date
    Jul 2013
    Posts
    276
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Feedback Score
    1 (100%)
    I would start at a 170 main and drop down
    50 or 52 pilot
    2 turns on air screw ,work in and out
    Needle I would start on the 4th clip from bottom
    That's pretty general for a starting point
    For the cr ignition ,not sure on plug gap,I think around,.26,.25 or .24
    See if anyone else chimes in
  3. #3
    Pro-X
    Join Date
    Oct 2013
    Location
    Phoenix Arizona
    Posts
    635
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Feedback Score
    0
    Quote Originally Posted by 2k1lvr View Post
    You omitted two of the most important things that will affect your jetting!!!
    We need to know what your intake set up looks like ( the type and size of air filter and the shape/length of the connection between the carb and air filter)
    We need to know if your TRX5 pipe is center mount or out of frame silencer.
    The bore size, reeds and ignition has very little effect on the main jet size.
    Reeds can affect the pilot jet, needle and clip position.
    The dome shape or volume has little effect on the main jet.
    Different brands of race fuel can sometimes affect the main jet as much as 3 sizes to get the same power.
    The needle taper/desiginator and clip position will often affect the optimum main jet size.
    I assume your altitude is about 1000 to 2000 feet elevation temperature average is around 80 deg. F and humidity is around 50 %.
  4. #4
    Pro-X
    Join Date
    Oct 2013
    Location
    Phoenix Arizona
    Posts
    635
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Feedback Score
    0
    Quote Originally Posted by PORTED R View Post
    50 or 52 pilot
    You did not state the needle designator. Different needles will affect which pilot, slide and main jet will be an optimum combination.
  5. #5
    Rider
    Join Date
    Jul 2013
    Location
    indianapolis
    Posts
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Feedback Score
    0
    it has a uni foam filter dgh needle stock intake boot and stock airbox and boot with no lid and std mount trx5 with power core 2 muffler
  6. #6
    Pro-X rk88r's Avatar
    Join Date
    Jul 2013
    Location
    central mn
    Posts
    514
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Feedback Score
    0
    I would start with the needle in the middle or fourth clip from the top if it's cool out. If you experience a lean spot at 1/2-5/8 throttle ditch the dgh for a dej.
    '99 Laeger narrow, cr link, +3+1 protrax, Peps, with a LED 363
    '88 265 pv peps
    One other '88
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
